lenena
May 21, 2016Initiate
Need advice with my EX7000 and my BOX TV
Hello, I have a LIVEBOX ( Orange ). I turned OFF his Wifi and plug a ROUTEUR "Netgear R8000-100PES Nighthawk X6 AC3200 Tri-Band". In another room I have an extender "Netgear Nighthawk AC1900 EX7000-1...
- May 21, 2016
IPTV service usually uses IP Multicast. Log into your R8000, go to ADVANCED > Setup > WAN Setup, uncheck the Disable IGMP Proxying checkbox and click Apply.
TheEther
May 21, 2016Guru
lenena
I JUST CAN'T BELIEVE IT..... IT'S WORKIIIIIIIIIIIIIIIIIIIIIIG !!!!!! I don't know how to thank you because I was absolutely depressed and fighting since 15 days !!!!! 3 people ( I mean "expert"...) came without finding the problem... I 've changed all the materials three times...!!!! YOU ARE JUST MY HERO TODAY "TheEther".... THANK YOU VERY VERY VERY MUCH. You have all my gratitude ! :-))))
