Raj_Govender
Jan 02, 2019Follower
Need help to reset to default settings WNR2000v5
I need some help to reset my Netgear Extender WNR2000v5 to default settings. This extender does not have a small pin hole in the back to reset.
- Jan 02, 2019
That's a router, not an extender.
There is a reset pin hole on the bottom of the router, see page 111 of the owner manual ( http://www.downloads.netgear.com/files/GDC/WNR2000V5/WNR2000v5_UM_20Nov2014.pdf )
Jan 02, 2019Guru - Experienced User
