MaChine05's avatar
Feb 09, 2022
Need Recommandation: wifi extender with different password
I want to buy a wifi extender/repeater/booster. My original wifi has no password. I want the extender to build a wifi with different ID and a password. Is there any recommendation? If possible, please recommend some cheap ones and some nice ones.
    • MaChine05's avatar
      MaChine05
      Tutor
      Can ‎NETGEAR EX3800-100FRS or EX3700-100PES does the job? I bought two products from other brands. One cannot connect to a wifi without password. The other one could not set a different password from the original wifi. I want to make sure before purchase. Thank you in advance.
      • plemans's avatar
        Why is the connection open?
        A better description of whats actually going on might help more.
        If its a public wifi that needs credential or a portal, a standard extender won't work.
        So whats actually going on?
