ahiqbal's avatar
ahiqbal
Follower
Nov 24, 2019
Net gear AC1200 Wireless Wifi Range Extender (EX6200) Simultaneously extend 2 different wifi signals
Hi,
My DSL modem transmts 2.4GHz signals and I have attached a TP link router to the main modem that transmits 5GHz signals. I just wanted to ask does anyone know that can I extend both of these wifi signals i.e. 5 & 2.4GHz (one from primary DSL and other from a wired router) simultaneously, using Net gear AC1200 Wireless Wifi Range Extender (EX6200)? If yes can somebody elaborate the method? and if not can you mention any other extenders that might have this feature?
Thank you
1 Reply
  • plemans's avatar
    You should be able to it fairly easily if you have the SSID's seperated out.
    Just make sure to follow the manual setup process on page 17 of the manual. it allows you to select which wifi signal to extend. You'll be able to select which one you want for 2.4ghz and 5ghz.
    https://www.netgear.com/support/product/EX6200
