oldguy308
Aug 27, 2018Aspirant
Net gear N300 range extender
If the n300 will not connect to an I-pad2, why doesn't the doc say so?
DexterJB
Sep 02, 2018NETGEAR Moderator
Hi oldguy308,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
oldguy308
Sep 05, 2018Aspirant
I gave up on an n300 trying to connect to the IPad, and even tried an ac750 with WPA2 encrypt, and the Ipad still refuses to connect. Even at a distance of one foot! Meanwhile 30 feet away, my android phone connects up instantly and works fine. Is Apple software excluding non-Apple gear? Seems like it.
