thesieger
Feb 16, 2018Aspirant
Netflix not streaming
Hello. I installed the extender. All works fine besides Netflix streaming. I can get I to Netflix but streaming does not work. It times out. I tried to only enable the 5 Band or also with or without ...
jvasanth1984
Feb 16, 2018Virtuoso
Hi thesieger,
Try to modify wireless channel on your main router since that may impact signal which you get from your extender.
- thesiegerFeb 17, 2018AspirantThank you. I tried already. No impact.
- jvasanth1984Feb 17, 2018Virtuoso
Hi thesieger,
What is the speed which you get from main router at the place where extender is and what speed do you get on the device from which you are trying to access Netflix?
- thesiegerFeb 17, 2018AspirantHello. The connection speed is 270 from the router to the extender and then up to 400 to the end device.
Directly to the router with the end device 105, then connected to the extender 90 mb.- jvasanth1984Feb 18, 2018Virtuoso
Hi thesieger,
Speed via extender looks fine compared to router. So you shouldn't face issues while streaming Netflix. May I know from what device are you trying to stream Netflix? What is you try from a different device just to find out where issue could be?
- thesiegerFeb 18, 2018AspirantHi. I use all my IOS devices at newest software versions. my Windows 10 laptop does also not stream when connected to the extender.
