thesieger
Feb 16, 2018Aspirant
Netflix not streaming
Hello. I installed the extender. All works fine besides Netflix streaming. I can get I to Netflix but streaming does not work. It times out. I tried to only enable the 5 Band or also with or without ...
thesieger
Feb 18, 2018Aspirant
Already done twice.
jvasanth1984
Feb 18, 2018Virtuoso
Hi thesieger,
Try modifying wireless channels on both bands on your main router to check if that helps. You can try wifi analyzer apps which can check and suggest best channel for your environment.
- thesiegerFeb 18, 2018AspirantThis I did all as it is suggested for normal Problem resolution. Do you have experience with EX7500 and streaming problems?
- jvasanth1984Feb 18, 2018Virtuoso
Hi thesieger,
Never heard any so far. How about if you try to stream anything else like Youtube?
- thesiegerFeb 18, 2018AspirantYouTube and other streaming services work. It is somewhat a joke that NETGEAR advertises this product with a slogan that Netflix streaming is then available everywhere.
- jvasanth1984Feb 23, 2018Virtuoso
Hi thesieger,
Please contact Netgear support since this looks odd. It works for others who have the same model.
