johnkf
Mar 31, 2021Aspirant
Netgear AC1200 WiFi range extender EXS6190
Having problems with my unit getting the following Message "LAN Disconected then - 5-30 Seconds LAN connected this stops any program that was been streamed then have to re start unit has worked ok for last 6 months
Help Pls
Thanks
John
You have the EXS6190
What fimrware is on it?
What router is connected to it?
Do you have the extender hardwired in or what device is giving you the lan notice?
Do all devices have this issue or just one?
- nikim72Aspirant
johnkf wrote:Having problems with my unit getting the following Message "LAN Disconected then - 5-30 Seconds LAN connected this stops any program that was been streamed then have to re start unit has worked ok for last 6 months usps tracking
Help Pls
Thanks
John
Hey john,
If you config system manually , let it to reset.. May your lan assign similar ip to other devices.. Not sure this could be the problem , but can be one of case... Reset and do again..
