kdon23's avatar
kdon23
netgear ac2200 triband nighthawk
I went thru the set-up successfully, trying to see if the setup is working correctly.  When the extender is synced with the router (Nighthawk AX4 Wifi 6 Router RAX40) only the 2.4 ghz light is lit, and only when it is plugged in next to the router.  When I move it to the next room the 2.4 nor the 5.0 light up?  In a successful set-up should both be lit?
Thank you, tried to find the answer but nothing
  • plemans's avatar
    what extender do you have? AC2200 is a speed.
    Usually with the extenders, the 2.4ghz/5ghz light comes on when a device (phone, tablet, pc, etc) is connected to it. It doesn't signify the connection to the router. Again, not 100% because you didn't include extender model.
    Also, I think all the AC2200 extenders are mesh extenders. meaning its your device (phone, tablet, etc) that roams between the router and extender as needed. If you set it up in mesh mode.
