iMact3
Mar 16, 2019Aspirant
Netgear AC750 EX3700 SETUP
Can I setup EX3700 – AC750 WiFi Range Extender with a router that is 20 meters away without WPS?
Mar 16, 2019Guru - Experienced User
Try it...distance maybe too far. You might set up the EX in the same room as the wifi router first, then place in remote location afterwards.
