Jacob420
Mar 25, 2018Aspirant
NetGear AC750 Extender
Okay so this is really frustrating. I used to be able to Connect and be fine with my wifi range extender but it suddenly started some bs. which is funny bc it had a 90 day thing.. go figured, but anyw...
jvasanth1984
Apr 03, 2018Virtuoso
Hi Jacob420,
Please try changing wireless channel on router for 5GHz and also look for firmware upgrade if any for your EX3110.
- Jacob420Apr 04, 2018Aspirant
When i try and update, it wants me to burn it on a disc for some odd reason. Then when i get a disc it says its not valid. Is there seriously any other way to download, because netgear is starting to look like a joke to me.
- jvasanth1984Apr 04, 2018Virtuoso
Hi Jacob420,
I'm afraid if you are trying to open the firmware file. You should not open it rather you need to login to extender, goto firmware update and choose the file by browsing and selecting it.
