maldaegary's avatar
maldaegary
Follower
Oct 22, 2018
NETGEAR AC750 WiFi Range Extender (EX3700-100NAS) / Chromecast / Google Home Assistant
Hello,
I have utilized EX3700 to extend my wifi network to the backyard. I have used different SSID to extend the network.
Wifi is now reaching everywhere in the backyard and it is working great.
However, when my mobile device is connected to the backyard extended network, it does not recognize as being on the same network as Chromecast, which is connected to the original network.
If I were to simply change the SSID of the backyard network to the same SSID as my main network, will it fix my issue?
Thank you very much in advance for your expertise.
  • Hi maldaegary,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi maldaegary,
    Welcome to the community!
    1. What is the firmware version of the extender?
    2. Does the issue persist whether your devices are connected to the 2.4GHz or 5GHz band of the extender?
    3. Can your device (preferably computer) ping your Chromecast?
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi maldaegary,
      Dexter
      Community Team
