malteser's avatar
malteser
NETGEAR AC750 WiFi Range Extender (EX3700-100NAS) / Chromecast / Google Home Assistant
I purchased an AC750 WiFi Range Extender Essentials Edition Model EX3700.  I'm trying to install it using the "WPS" method as I use a MacBook Air and not a desktop.  I followed the instructions to a ...
  • StephenB's avatar
    Dec 27, 2018
    You don't need to use the WPS method with your MacBook Air, so I suggest using the web browser setup method.
    Reset the extender, and join the NETGEAR_EXT network.  Then browse to www.mywifiext.net and follow the browser prompts.
    The manual is here: http://www.downloads.netgear.com/files/GDC/EX3700/EX3700_UM_EN.pdf
    The instructions for what I am suggesting are on page 11 ( Connect with Web Browser Setup )
