Amatex's avatar
Amatex
Netgear Ax1800 WIFI 6 Extender wont connect
Hi all
So I am having an issue where my Netgear AX1800 will not connect to my Fritzbox 7590/ to the Internet.
I go threw the setup on the nighthawk app and it says it's connected but it does not find an IP address
I tried to type it in manually still nothing
It used to be plug in and setup and off I go but something has happened and I'm not sure if it's a firmware issue or something else.
If you need anymore info let me know
  • Okay just set it up again and this I noticed it says the wifi/ extender is connected however I noticed under the wifi > IP address tab the Gateway and DNS service is undefined
    It will connect to the wifi but it's just showing as no internet access on both wired and Wireless devices.
