Ahmedyounes
Dec 16, 2019Aspirant
Netgear c7500 or c7000
Which one is best to buy . Netgear c7500 or netgear c7000?
If it was me choosing, I'd be choosing between the c7000 and the c7800. the c7800 has both the wifi benfits (that you won't really see) and the benefit of having docsis 3.1 (which you will see if you have potential for gigabit).
the other option (that I'd recommend) would be buying a seperate modem/router device. When you buy combo devices, the ISP controls the firmware. when you seperate them out, you at least control the firmware on your router. Plus if something goes wrong, you're only out a single device instead of needing to replace the whole combo device. for a little more you could get a cm1000 and an R7800 and have a nice combination.
- AhmedyounesAspirantOh man its c7500 not c7800
- plemansGuru - Experienced UserI know. But I'd skip the c7500 for the c7800 if I was upgrading past c7000.
