Henryvl
Mar 21, 2017Aspirant
Netgear EX2700 - 100UKS - country of origin
I bought this range extender in the UK. It has a country of origin as DE - Germany. How do I change this to UK? Thank you.
Henryvl
Mar 23, 2017Aspirant
DarrenM wrote:Hello Henryvl
Have you tried to factory reset the extender?
DarrenM
Yes, and it shows the country of origin as 'Europe'.
It is still showing DE on my wifi analyser though.
The firmware is 1.0.1.10
DarrenM
Mar 24, 2017Sr. NETGEAR Moderator
Hello Henryvl
Is this causing a issue on the network?
DarrenM
- HenryvlMar 24, 2017Aspirant
Not that I can see.
- schumakuMar 25, 2017Guru - Experienced User
It's the same regulatory domain anyway.
Curious what WIFi analyzer you are using btw. Thank you!
-Kurt
- HenryvlMar 25, 2017Aspirant
I use 'Wireless Diagnostics' which is on my Mac.
I have two Netgear enhancers, and they both show as 'DE' country of origin.
Interestingly there is not option for DE or UK in the netgear set up.
Just Europe.
