Harald42
Sep 19, 2017Aspirant
Netgear EX2700-100PES - can not access http://www.mywifiext.net/
Once again a often asked question: How to Acces the Admin-Interface of the (very good) working repeater. Setup was no problem - works very good. But no Access to the management Interface: I am ...
DarrenM
Sep 21, 2017Sr. NETGEAR Moderator
Hello Harald42
A cable would be the best way and if you do not know the ip address and can not access the router then no really good way to manage the device.
DarrenM
- Harald42Sep 22, 2017Aspirant
Hello DarrenM,
thank you for your answer.
I do not look for the "best way" or a "good way"
I accept the worst way - if it works.
My new findings are.
All Clients in the network are seperated - no communication between the clients.
nslookup www.mywifiext.net
Server: 192.168.10.1
Address: 192.168.10.1#53Name: www.mywifiext.net
Address: 192.168.11.194I believe that this is the right adress of the repeater. But there is no access because a firewall is blocking everything. This is a very common setup in public wlan infrastructures.
What is a way to the management Interface?
Harald
