lllcandymanlll
Nov 18, 2016Aspirant
NETGEAR EX2700-100UKS internet speed drop
has worked fine for months and now sometimes works and sometimes relentlesly just gives around 50kb per second, sometumes gives 16 mbs and then drops again? did notice a few times there was a red light on the router led? could it be receiving interference of late and thats why i have this problem?
- ive tried changing the channel before and it never helped, ive also tried changing the angle of my antennas before which never helped but since my post i tried moving the antennas again and im guessing ive found the sweet spot. my repeater is on the borderline of receiving through a window or not receiving through a brick wall. The repeaters worked fine for months until recently, im guessing some furniture has moved at some point and changed the signal pattern, its all good now though :)
- lllcandymanlllAspirantive tried changing the channel before and it never helped, ive also tried changing the angle of my antennas before which never helped but since my post i tried moving the antennas again and im guessing ive found the sweet spot. my repeater is on the borderline of receiving through a window or not receiving through a brick wall. The repeaters worked fine for months until recently, im guessing some furniture has moved at some point and changed the signal pattern, its all good now though :)
- DarrenMSr. NETGEAR Moderator
Hello lllcandymanlll
Yes it could be interference you could try to change the wireless channel on your router to see if that helps or you may need to move the extender in the home to a different area.
DarrenM
