jamielasagna's avatar
jamielasagna
Netgear EX2700 extender connected via ethernet, but saying I'm not connected on the Netgear Homepage
Title is pretty self-explanatory, my PC is connected to the Extender via Ethernet, but whenever I attempt to go to the Extender's homepage, the website says that I am not connected to the Extender's WiFi network. I've checked to see if I am connected to any other networks and I am not. I can't connect the Extender to any other networks due to the inability to change networks on the homepage. Any help would be appreciated.
  • plemans's avatar
    Are you able to access it using its ip address? NOT using the mywifiext . net
    You can find its ip address in the routers attached devices page (or equivelent)
    • jamielasagna's avatar
      jamielasagna
      Both 192.168.1.1 and 192.168.0.1 time out whenever I try and search them.
      • plemans's avatar
        those are router ip addresses, not extender.
        what router do you have?
        if you open a command prompt on your computer, type ipconfig,  the default ip address should be the address for the router.
