TonyFG1971
Oct 27, 2021Aspirant
Netgear EX2700 Poor Signal issues
Hi, I’ve connected my Booster to my Router in my Lounge (Ethernet 100mb Internet) & home Network, with the Booster plugged in the my Sons bedroom (in same floor, as live in a Flat) so he can play onl...
michaelkenward
Oct 28, 2021Guru - Experienced User
TonyFG1971 wrote:
Hi,
What is that router?
Is he using wifi or plugging into the Ethernet port on the EX2700?
You might find that Powerline Ethernet is more reliable.
- TonyFG1971Oct 29, 2021AspirantThank you.
I have a Virgin Hub 3 Router (Arris Group).
Can I check that if my Router is in my Lounge & Booster in a Bedroom that it would be better to connect a cable from the Booster to my PS4 to improve the speed?
Also, do Wi-Fi channels make a difference, as I’ve got everything set up auto channel optimise?
This however doesn’t allow me to specify 2.4G instead of 5G which I believe is better when further away?
Thanks,
Tony
