TonyFG1971
Oct 27, 2021Aspirant
Netgear EX2700 Poor Signal issues
Hi, I’ve connected my Booster to my Router in my Lounge (Ethernet 100mb Internet) & home Network, with the Booster plugged in the my Sons bedroom (in same floor, as live in a Flat) so he can play onl...
michaelkenward
Oct 28, 2021Guru - Experienced User
TonyFG1971 wrote:
Hi,
What is that router?
Is he using wifi or plugging into the Ethernet port on the EX2700?
You might find that Powerline Ethernet is more reliable.
TonyFG1971
Oct 29, 2021Aspirant
Thank you.
I have a Virgin Hub 3 Router (Arris Group).
Can I check that if my Router is in my Lounge & Booster in a Bedroom that it would be better to connect a cable from the Booster to my PS4 to improve the speed?
Also, do Wi-Fi channels make a difference, as I’ve got everything set up auto channel optimise?
This however doesn’t allow me to specify 2.4G instead of 5G which I believe is better when further away?
Thanks,
Tony
Thanks,
Tony
