KenzaXI
Jul 13, 2018Follower
Netgear EX2700 WiFi extender suddenly stopped working?
Hi, I brought a Net Gear N300 EX2700 WiFi Range Extender on 9th January 2018. It had been working great until yesterday, all of a sudden yesterday, all my devices were able to connect to the extender...
tuna_on_rye
Sep 10, 2018Aspirant
I am having the same problem. It worked fine and it just stopped working. That is, I can no longer connect to my wifi Tuna_EXT. It has worked fine for a year. See attached screengrab.
Sep 13, 2018Guru - Experienced User
Actually your symptom sounds a bit different. Others on this thread can connect to the extender network, but are having trouble reaching the internet or their router. You aren't able to connect to the extender network.
Did you try restarting the extender? You could also try resetting the extender, and then setting it up again.
