cramcram
Aug 18, 2016Follower
Netgear EX3700-100PES turn wifi signal off
I just bought a Netgear EX3700-100PES Wlan Range Extender and successfully installed it as an access point. I'm having two questions:
1) Can I completely turn off the wifi signal (at night) based on a schedule?
2) Can I completely turn off all the status lights on the Extender?
Hope somebody can help.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello cramcram
You would have to check the schedule settings of your router to shut down the internet for the extender at a certain time by using the extenders Ip address. I do not believe you can change the lights on the extender.
DarrenM
