rbscycle
Nov 07, 2016Aspirant
Netgear EX6100, 10.0.0.250 IP Address after a reset
Initially worked fine. Decided to set it up as an Access Point. Setup failed. Did a reset and tried the setup again, it failed again. Tried to reinstate as the original Extender. After some poking around, found it had a 10.0.0.250 IP. I could connect to the Netgear home page with it. Tried to fill out the "Create New Account", the page resets and back to the beginning.
Hello rbscycle
Make sure you do not have a pop up blocker or ant virus causing the issues when setting up the extender.
DarrenM
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello rbscycle
DarrenM
