Anonymous
Aug 11, 2017Netgear EX6100 Router to Extender 5GHz band won't connect
Hi everyone, I have been through the setup process many times, but my extender just doesn't want to connect to my router on the 5GHz band. It will connect to and broadcast the 2.4GHz just fine an...
exxtreme76401
Aug 11, 2017Aspirant
the red means its not getting a strong signal. is it on the router or the device side?
Anonymous
Aug 11, 2017I can get a solid 5GHz signal with my laptop in the exact location of the extender, so the 5GHz signal from the router is fine.
- exxtreme76401Aug 11, 2017Aspirant
the laptop is using a diffrent antenna and position. which light on the extender is red. just b/c your laptop has a stong signal doesnt mean that something isnt blocking the signal behind a chair or through you. as the attenna in a laptop is normally in the sceen it tends to have more line of sight with the router than a extender plugged in the wall.
- AnonymousAug 11, 2017
When I say the signal is red, this is what I am referring to. On the setup page, not the extender itself.
- AnonymousAug 12, 2017
It could very well be a setting on my router that is not allowing the extender to connect to the 5GHz band, but I would not know where to start with changes. During the setup process, the extender gets a 100% signal from the 2.4GHz band and a 78% signal from the 5GHz band, so my guess is the signal isn't the issue. Wouldn't a 78% signal be enough for the extender to establish a connection?
