chyavana
Sep 30, 2023Aspirant
Netgear EX6110 wifi range extender now requires manual allocation of IP addresses in Linux
I have a Netgear EX6110 WiFi Range Extender that was purchased in February 2023 and is still under hardware warranty. Previously it could be setup without much effort with my Optical Network Unit (ON...
Oct 02, 2023Guru - Experienced User
did you try setting it up using the installation assistant and not wps?
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
chyavana
Oct 04, 2023Aspirant
Thank you for your reply.
I have tried the following:
1. Reset to factory defaults and set up with "Genius".
2. Reset to factory defaults and set up wit WPS.
3. Set up with "Genius">
4. Set up with WPS.
The behaviour does not change.
I wonder if some setting on my GPON/ONT unit causes this behaviour?
