fjkndy
Oct 11, 2016Aspirant
Netgear EX6150 Extender Installation
Windows 10 OS, ISP Cox Cable. Just installed Netgear C7000-AC1900 modem/router. ISP is Cox Cable. It performs better than Motorola SBG6580 Gateway it replaced. I am now attempting to reconnect my Ne...
fjkndy
Oct 13, 2016Aspirant
Thanks, Darren, for help. Yes, I've reset numerous times with the same result. Maybe too many resets. If the extender can be seen logging into the C7000 gateway using Netgear Genie and displays in the Network Map as EX6150 with an IP: 198.162.0.22, we must be close. I compared the MAC address that appears in Genie as A0:63:91:CE:4E:A8 to the values on the extender label and note the only differences are there are two Mac addresses and the string sequences only vary in the last two positions where they end in :A6 and :A7.
DarrenM
Oct 13, 2016Sr. NETGEAR Moderator
Hello fjkndy
have you tried to add those mac address to the allowed list on the router?
DarrenM
