Lakevilledon's avatar
Lakevilledon
Follower
Jan 23, 2021
Netgear EX6150 Multiple devices on a single network?
I have the Netgear EX6150 Extender and am wondering can I put multipal extenders on the same WiFi Network?
THX
1 Reply
  • plemans's avatar
    Yes. you can.
    But I'd highly recommend against daisy chaining or you'll get significant throughput drops.
    Daisy: Router------>extender------>extender
    Star:  Extender<---------router-------->extender
    I'd also caution that if you're using a mesh extender and the extenders are to close, they can sometimes end up attaching to each other and not back to the router.
