S_Dent
Apr 18, 2018Follower
Netgear ex6200 connection issue
Hiya,
Wondering if anyone can help, I've bought a new range extender, updated the firmware, used the genie to connect the Extender to the Router, all seems well and connected that end but whenever I try to connect devices to the extender it tells me there's an authentication problem and defaults to the router signal instead. Idk what else to do.
Many thanks
Many thanks
1 Reply
- DarrenMSr. NETGEAR Moderator
You may want to factory reset the extender by holding the reset button for 10+ seconds then try to set the extender up again.
DarrenM
