jpow01
Oct 21, 2018Aspirant
Netgear EX6200 creating Vlans
As you will notice in the picture below I have only created 1 LAN for each of the 2.4 and 5 GHz channels.
For some reason however, my extender will allow itself to develop alternate VLANs ,...
schumaku
Oct 21, 2018Guru - Experienced User
Would be interesting news if Netgear consumer devices were supporting VLANs. Talking more of WiFi SSIDs (Wireless Network Names) here. Can't see the pictures yet as these require moderator apporval.
Best guess you talk for example of:
• Existing WiFi network name. MyNetworkName
• New extended network names. MyNetworkName_2GEXT and MyNetworkName_5GEXT
- StephenBOct 21, 2018Guru - Experienced User
You should be able to see the images now.
I see no evidence of any vlans.
Note that if you are using one SSID on your network, the extenders and the router will still use different BSSIDs. Those can result in multiple networks with the same name in your wifi clients.
- jpow01Oct 21, 2018Aspirant
I've had this router for several years now. This is the base router. As you will notice I do not have bridge/vlan routing enabled or configured.
