jpow01
Oct 21, 2018Aspirant
Netgear EX6200 creating Vlans
As you will notice in the picture below I have only created 1 LAN for each of the 2.4 and 5 GHz channels.
For some reason however, my extender will allow itself to develop alternate VLANs ,...
schumaku
Oct 21, 2018Guru - Experienced User
jpow01 wrote:
For example I named my 2.4 GHZ channel extend24; after a while my devices would connect to extend24 2 or extend24 3 or extend24 4. They were not connecting to the SSID I had made but a replica with a different number to it. I don't know how best to describe it.
What you describe here is more an oddity in how some clients (say Windows) are handling the stored or known wireless (and sometimes even wired) connections and the sometimes weired logic of mapping network names with locations. We randomly see (or have seen) similarity things, and some times later it's like some "garbage collection" going on cleaning up and streamlining these multiple entries into a single one. You might ask Microsoft respectively the computer OEM which licensed Windows what does cause this.
It's not that the wireless name which has changed.
jpow01
So it would just be the way that the PC NIC stores SSID's? Are there any known security risks associated with this? Would setting a static IP for my devices help to connect it to a specific SSID or would it still just be an issue from the PC NIC? My next thought was it could have been that I have set some devices with a static IP through Address Reservation setting; I don't know if this could cause anything like this.
