Preylord
Dec 18, 2015Aspirant
Netgear EX7000-100PES Nighthawk .....not able to setup!
Hello there, i got my EX7000 these days an tried today to set it up as AP.....but two steps further i get first problems :( My WLAN Device (HTC M7) can connect to it and i filled out the forms but a...
Preylord
Dec 22, 2015Aspirant
Well I used this cable on the other AP which worked fine. Tomorrow I got another Router for testing if the netgear works on him.....I also got a second netgear here but its still in original packing....if I dont get the First to work booth go back to amazone instant! Thy anyway for your time so far :)
- TheEtherDec 22, 2015Guru
Is the other AP connecting at 1 Gbps with the same cable? 100 Mbps Ethernet only uses 2 out of the 4 pairs of wires in the cable. Gigabit Ethernet uses all 4 pairs. If even one wire is bad in the cable, Gigabit Ethernet will not be possible.
