markshores's avatar
markshores
Follower
Nov 11, 2020
Netgear Extender WN3000RPv2 (Can not get valid IP)
After doing a factory reset of the extender the device will no longer give a valid IP thus not able to login to dashboard.  I tried multiple times same results.  Is there a workaround for this or if the extender pretty much a brick?
1 Reply
  • plemans's avatar
    how are you connecting to it?
    hardwired? wireless?
    Have you tried hardwiring into it and running through the setup?
    Have you tried installing it using wps? I usually don't recommend that method but sometimes it works great.
