Mcoo
Mar 09, 2017Aspirant
Netgear Genie constantly pop-up
I can't get rid of a pop-up on my Mac that reads: "NETGEAR Genie is searching for WiFi networks in your neighborhood. This takes approximately 1 minute." I've used a range extender for a few yea...
DexterJB
Mar 19, 2017NETGEAR Moderator
Hi Mcoo,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Mcoo
Mar 31, 2017Aspirant
It's a WN3500RP Universal Dual Band WiFi Range Extender, Wall-plug Edition.
I temporarily solved the problem via but it's back. If produces a list of nearby Wifi options -- often failing to include my own. When I try to complete the options it times out and starts again a few minutes later.
