dmna007
Apr 15, 2020Tutor
Netgear Knighthawk x6 and DG834g
Hi,
I have a Nighthawk x6 R8000 wifi router, I also have an old Netgear DG834g, what i am looking to do is get Wifi into my garage, the garage has a spare RJ45 data socket which is part of the CAT5 cabling infrastructure, this socket goes back to a patch panel which goes into a switch which is plugged into the R8000.
What is the best way for me to get wifi into the garage? Could I use the RJ45 socket and the DG834g? If not what device would you recommend?
Many thanks for any help you can offer.
Thank you
Its a bit more than just plug and play but not a whole lot. setup is pretty easy with these devices.
Here's what I'd recommend. go here: https://www.netgear.com/home/products/networking/wifi-range-extenders/
then you can sort extenders by features you'd like. (access point mode isn't on there)
Once you've narrowed it to a few devices. Just pick the one you want and look up its manual (netgear.com/support/)
In the manual it'll tell how to turn access point mode on if its got it. Most of them do but its always good to check. (its mostly the base model devices)
again, or you can buy a router and run it in Access Point mode. Amazon has some pretty decent prices on renewed routers right now. Plus it gives you a backup router to use if your primary dies. (just make sure its ran in Access Point mode)
Even if you could make it work, I wouldn't. the DG834 was made in 2006 and is a 10/100mbps, 54mbps/wireless adsl device.
A cheap dual band extender in AP (access point) mode would function much faster, be more secure, and have better range stabilty than trying to rig something to work with the DG.
At a certain point, electronics do need to be discarded, I think 14 years is probably there. :)
- dmna007Tutor
Many thanks, you make a very valid point :-)
Are you able to recommend a netgear "dual band extender" which can run as an access point?
The garage is 30m away from the house with no wifi signal currently, am I assuming correctly that the new device you recommend, I will plug this device into my structured cabling solution via the ethernet port in the garage and this new device will then communicate with the existing Netgear Knighthawk x6 to set everything up or is there more involved?
Thank you again.
