wsch001
Aug 02, 2015Aspirant
Netgear model EX6200 randomly assigns a Class B subnet when DHCP is enabled
Hi, Am using a Ntegera WiFi extender, EX6200. Extends WiFi from an existing 2.4GHz router, which I call the master. I have enabled both 5Ghz and 2.4GHz range in the Netgear WiFi extender. ...
nhann
Aug 07, 2015NETGEAR Employee Retired
Hi wsch001,
Thanks for writing in.
What connection does your Mac receive when connecting directly to your router?
Please try navigating to the Network Preferences and reset the configurations.
Let us know how it works for you.
NhanN
- wsch001Aug 22, 2015Aspirant
When connecting directly to the router it does get a correct Class C subnet mask.
Current settings are 192.168.8.4
Subnet Mask 255.255.255.0
Router 192.168.8.254
When accessing the network with the extender, it gets assigned an IP address but the subnet mask is only 255.255.0.0 and no router address.
Hence no internet access either on the 5GHz and 2.4 GHz band.
Frustarting is that this does not happen all the time, but only randomly.
- nhannAug 24, 2015NETGEAR Employee Retired
Can you please try setting a static IP for your Mac?
http://kb.netgear.com/app/answers/detail/a_id/25722/~/how-do-i-reserve-an-ip-address-on-my-netgear-router%3F- wsch001Aug 24, 2015Aspirant
I would love to do it, but this is *not* a Netgear router. It is a Netgear EX6200 wifi extender.
As such it's administartion user interface will not allow you to assign a specific IP address for a given MAC address. Wish I could do so.
