Jvonk69's avatar
Jvonk69
Follower
Jul 10, 2021
Netgear N300. No internet. Sign in. "Reset""1"
When I try to connect to internet, sends me to mywifiext site to sign in.
Says : "reset" "1"
Seen other posts with same problem and no solution.😡
1 Reply
  • plemans's avatar
    1. why are you connecting to the guest network? (in your photo)
    2. what router did you connect it to?
    3. did you setup the extender using wps or using the installation assistant?
    If you used wps, I'd highly recommend factory resetting the extender and installing it using the installation assistant
