QQT
Aug 09, 2016Follower
Netgear N300 or AC750?
I want to purchase a range extender to improve my wifi signals, and I'm currently looking at 2 models: N300 and AC750.
I read throught the specs, but I still didn't understand the differences between this 2.
Can anyone help clarify the differences between the two or let me know which one is a better choice for my case? Thank you!
My router is in the a bedroom, and I hardly get any signal from my garage which is around 40-50 feets away.
There's a couple walls, another bedroom, and a backyard between my bedroom and the garage,
In this case, which model would be a better choice to put in my garage?
1 Reply
- DarrenMSr. NETGEAR ModeratorHello QQT The Ac750 has some more range on it plus its a dual band extender so if you have a router with 2.4ghz and a 5Ghz network and supports AC the N300 has only a 2.4ghz network and supports up to wireless N. DarrenM
