Sharkyfin
Oct 31, 2018Aspirant
Netgear N300 Range Extender does not create Network Name
Model N300 Wi Fi Range Extender Model EX2700
Hi, I have two range extenders and set them up using the WPS auto option.
This created two additional connections - Network_Ext_1 and Network_Ext_...
Oct 31, 2018Guru - Experienced User
Does www.mywifiext.net show that the extenders are connecting successfully to the router wifi?
Sharkyfin
Unsure what you mean with the link www.mywifiext.net, this just brings up various instructions which do not help alas.
The extenders find my WIFI through the WPS - green lights good to go etc but when you try and connect in fails - It also does not create the correct address - i.e internet_ext_1 - it defaults to Netgear_ext which is not correct. Worked for 3 months then not - strange.
