Sharkyfin
Oct 31, 2018Aspirant
Netgear N300 Range Extender does not create Network Name
Model N300 Wi Fi Range Extender Model EX2700
Hi, I have two range extenders and set them up using the WPS auto option.
This created two additional connections - Network_Ext_1 and Network_Ext_...
Sharkyfin
Unsure what you mean with the link www.mywifiext.net, this just brings up various instructions which do not help alas.
The extenders find my WIFI through the WPS - green lights good to go etc but when you try and connect in fails - It also does not create the correct address - i.e internet_ext_1 - it defaults to Netgear_ext which is not correct. Worked for 3 months then not - strange.
Nov 01, 2018Guru - Experienced User
When you connect to the extender wifi network then It should give you setup options. Can you post a screenshot?
Overall, your symptom (client wifi is NETGEAR_EXT) suggests that WPS setup is failing.
- SharkyfinNov 07, 2018Aspirant
Thanks to all for assistance.
Resolution - unplugged for a week and placed in cupboard.
Factory reset with a paper clip.
Reconfigured with WPS button as before and today all is now well!
Perhaps the little badboys freeze on occasion.
