moose3473
Sep 17, 2018Initiate
NETGEAR N300 Wi-Fi Range Extender EX2700 Having issues with weak signal
Hello,
I currently have a Netgear N300 EX2700 WiFi Extender that I am using to extend coverage to my garage apt. where mother-in-law lives. The extender is plugged into an outlet in garage and...
Sep 18, 2018Guru - Experienced User
While you can daisy-chain extenders, it's not a great approach.
Is garage part of the house, or free-standing?
There are several apps you can use to check signal strength. Have you looked at the wifi signal strength of the extender network in her apartment? If that signal strength is good, then adding an extender in her apartment won't help.
Also, you can use the signal LEDs on the EX2700 (green/amber/red) to give you some idea on whether the issue is the link to the router, or the client link (to her devices).
moose3473
Sep 18, 2018Initiate
Hey StephenB,
Thanks for the info! It is a free standing garage. The signal from the router is good and all lights are green. She told me that it started working fine today so I’m not sure what the problem was. Can you send me the name of a couple of apps I can use to check the signal strength in her apt?
Thanks for your help!
Jason
Jason
- StephenBSep 18, 2018Guru - Experienced User
Unfortunately you can't find anything on iOS, since Apple doesn't give the right information in their normal API. There are some apps that graph connection speed, but that's not the same as signal strength. https://iphonebyte.com/wifi-signal-strength-meter-apps/
With Android, I suggest using Netgear WiFi Analytics. There are some others listed here: https://bestforandroid.com/wifi-signal-apps/
