mpd326
Feb 03, 2018Follower
Netgear N300 Wifi Range Extender (EX2700) having intermittent connection
I am using this wifi extender to strengthen the connection of my samsung tv through an ethernet cable connected to the extender. Whenever I begin watching the tv, a message displays saying the networ...
SiChris
Feb 03, 2018Aspirant
Had the same problem until I tried this. Using a microscrewdriver/paperclip end Press and hold the reset button for about a minute- it’s located under the wifi extender. The green light will turn orange during the reset phase, after one minute is up turn off the extender. After 10 seconds turn it back on- wait until the green light reappears, then use the same password and should all work again.
If it doesn’t log onto www.mywifiext.net and follow the instructions for a reset.
