dsfcom
Sep 03, 2018Aspirant
Netgear Netgear EX6200v2 Shows Connected to Internet but When Device Connects it has no Internet
When connecting to the extender from a particular device using the 2.4 or 5.0Ghz band, the device gets no internet (i.e., "No internet, secured"). I have attempted the solution given at the followin...
dsfcom
Sep 08, 2018Aspirant
Thank you for helping. Today I once again power cycled the entire network by unplugging power supplies from all three components (i.e., modem, router, extender) and then plugging them back in one at a time in the same sequence; waiting for each to fully start up. I then connected my laptop to the extender's 5.0Ghz band and the status indicated 'Connected, secured' which appeared to be a good sign.
When attempting a speed test at www.speedtest.net it repeatedly failed to initialize and when it did work the speed was very slow (39ms ping; 3.35Mbps down; failed up). In fact, overall performance of the 5.0Ghz band on this device is very bad and intermittent; to include access to network attached storage. From the same position in the house on my phone I have no problems at all using the 5.0Ghz band and get good results on the speed test using the same site and server (49ms ping; 29.9Mbps down; 11.4Mbps up). To answer your question; yes, I am intermittently able to ping the router when connected to the 5.0Ghz band.
----- BEGIN 5.0Ghz PING RESULTS ----- PS C:\WINDOWS\system32> ping 192.168.2.1 Pinging 192.168.2.1 with 32 bytes of data Request timed out. Request timed out. Request timed out. Request timed out. Ping statistics for 192.168.2.1: Packets: Sent = 4, Received = 0, Lost = 4 (100% loss), PS C:\WINDOWS\system32> ping 192.168.2.1 Pinging 192.168.2.1 with 32 bytes of data Reply from 192.168.2.1: bytes=32 time=4ms TTL=64 Reply from 192.168.2.1: bytes=32 time=4ms TTL=64 Reply from 192.168.2.1: bytes=32 time=3ms TTL=64 Reply from 192.168.2.1: bytes=32 time=3ms TTL=64 Ping statistics for 192.168.2.1: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 3ms, Maximum = 4ms, Average = 3ms PS C:\WINDOWS\system32> ping 192.168.2.1 Pinging 192.168.2.1 with 32 bytes of data Reply from 192.168.2.1: bytes=32 time=3ms TTL=64 Reply from 192.168.2.1: bytes=32 time=5ms TTL=64 Reply from 192.168.2.1: bytes=32 time=4ms TTL=64 Reply from 192.168.2.1: bytes=32 time=4ms TTL=64 Ping statistics for 192.168.2.1: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 3ms, Maximum = 5ms, Average = 4ms PS C:\WINDOWS\system32> ping 192.168.2.1 Pinging 192.168.2.1 with 32 bytes of data Reply from 192.168.2.1: bytes=32 time=7ms TTL=64 Reply from 192.168.2.1: bytes=32 time=12ms TTL=64 Reply from 192.168.2.1: bytes=32 time=1082ms TTL=64 Reply from 192.168.2.1: bytes=32 time=4ms TTL=64 Ping statistics for 192.168.2.1: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 4ms, Maximum = 1082ms, Average = 276ms PS C:\WINDOWS\system32> ----- END 5.0Ghz PING RESULTS -----
Attached are screen shots from router and extender perspectives when this device is connected to the 5.0Ghz band. Page 1 is from the router's perspective and page 2 is from the extender's perspective. The laptop's device name is 'VAD-DSFCOM-LT01'. During this period of troubleshooting the connection status on the 5.0Ghz band remained 'Connected, secured'.
I then connected to the extender's 2.4Ghz band. When attempting a speed test at www.speedtest.net it repeatedly succeeded and performance appeared very good (41ms ping; 50.38Mbps down; 11.50Mbps up). In fact, overall performance of the 2.4Ghz band on this device is very good; to include access to network attached storage. From the same position in the house on my phone I also have no problems using the 2.4Ghz band and get good results on the speed test using the same site and server (38ms ping; 42.9Mbps down; 11.5Mbps up). To answer the same question for the 2.4Ghz band; yes, I am consistently able to ping the router when connected to the 2.4Ghz band.
----- BEGIN 2.4Ghz PING RESULTS ----- PS C:\WINDOWS\system32> ping 192.168.2.1 Pinging 192.168.2.1 with 32 bytes of data Reply from 192.168.2.1: bytes=32 time=3ms TTL=64 Reply from 192.168.2.1: bytes=32 time=6ms TTL=64 Reply from 192.168.2.1: bytes=32 time=4ms TTL=64 Reply from 192.168.2.1: bytes=32 time=3ms TTL=64 Ping statistics for 192.168.2.1: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 3ms, Maximum = 6ms, Average = 4ms PS C:\WINDOWS\system32> ping 192.168.2.1 Pinging 192.168.2.1 with 32 bytes of data Reply from 192.168.2.1: bytes=32 time=5ms TTL=64 Reply from 192.168.2.1: bytes=32 time=4ms TTL=64 Reply from 192.168.2.1: bytes=32 time=4ms TTL=64 Reply from 192.168.2.1: bytes=32 time=5ms TTL=64 Ping statistics for 192.168.2.1: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 4ms, Maximum = 5ms, Average = 4ms PS C:\WINDOWS\system32> ping 192.168.2.1 Pinging 192.168.2.1 with 32 bytes of data Reply from 192.168.2.1: bytes=32 time=3ms TTL=64 Reply from 192.168.2.1: bytes=32 time=4ms TTL=64 Reply from 192.168.2.1: bytes=32 time=3ms TTL=64 Reply from 192.168.2.1: bytes=32 time=4ms TTL=64 Ping statistics for 192.168.2.1: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 3ms, Maximum = 4ms, Average = 3ms PS C:\WINDOWS\system32> ping 192.168.2.1 Pinging 192.168.2.1 with 32 bytes of data Reply from 192.168.2.1: bytes=32 time=4ms TTL=64 Reply from 192.168.2.1: bytes=32 time=3ms TTL=64 Reply from 192.168.2.1: bytes=32 time=4ms TTL=64 Reply from 192.168.2.1: bytes=32 time=5ms TTL=64 Ping statistics for 192.168.2.1: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 3ms, Maximum = 5ms, Average = 4ms PS C:\WINDOWS\system32> ----- END 2.4Ghz PING RESULTS -----
Also attached are screen shots from router and extender perspectives when this device is connected to the 2.4Ghz band. Page 3 is from the router's perspective and page 4 is from the extender's perspective. During this period of troubleshooting the connection status on the 2.4Ghz band remained 'Connected, secured'.
I suspect the 2.4Ghz band performs well but the 5.0Ghz band does not. Here lies my predicament; I do not understand why this is the case. While I could simply stick with the 2.4Ghz band and ignore the 5.0Ghz band I would like to be able to use the full functionality of the extender on this machine.
schumaku
Sep 08, 2018Guru - Experienced User
What does hit my eyes from the screenshots is the fact that the extender does show the very same Virtual MAC address for multiple devices/real MAC. Kind of predictable things are flaky...
- dsfcomSep 16, 2018Aspirant
Hello and thanks again for helping! My understanding of how the extender works is that it provides two virtual MAC addresses; in my case they are:
A6:04:60:2A:1C:8C for the 2.4Ghz band
A0:04:60:2A:1C:8D for the 5.0Ghz band
It seems that any device connected to the extender will be assigned one of these two MAC addresses and then be passed to the router with both the devices MAC and the assigned virtual MAC. On the router side, each device connected to the extender is listed twice with the same IP but two different MACs. Is it not supposed to work this way?
- StephenBSep 17, 2018Guru - Experienced User
The extender itself has a virtual MAC address on the router for each band, and each client device should also have it's own virtual MAC address on the router. That's needed because the router needs a MAC address for each device in order to route the data (the IP address by itself isn't enough), and because the extender needs different client-device MAC addresses for the two hops (client->extender and extender->router).
There is described in the kb article here (though it is pretty complicated): https://kb.netgear.com/24806/How-can-I-retrieve-the-virtual-MAC-address-from-the-Wi-Fi-Range-Extender-to-setup-an-Access-List
- dsfcomSep 24, 2018Aspirant
Thank you StephenB. I am not sure we are talking about the same thing; either that or I have no idea what you mean. When I connect a device to the extender it is listed on the connected devices page with its real MAC and virtual MAC. Multiple devices connected to the same wireless band have the same virtual MAC. I am currently seeing five devices with the same virtual MAC on the extender end. On the router side I see the same devices; each with its real MAC and virtual MAC as two separate entries on the device list page. These MACs are the same as the ones on the extender end. Should they each have a different virtual MAC? Is there something wrong with my extender causing the five devices to all have the same virtual MAC?
