Eyedesigns
Jun 06, 2020Aspirant
Netgear Nighthawk AC1750 not working
The lights are on but these are flashing- internet, 2GHz, 5GHz. Can not connect to WiFi. Rebooted. Cable guy checked and internet is fine. Says router went out. Only had it 2 yrs
What router? AC1750 is a speed, not a model.
What modem is it connected to?
have you tried a simple factory reset and reinstall? push and hold reset for 7-15 seconds while its powered on. Then let it reboot and try installing it.
- EyedesignsAspirantModel is R6700v3. I restarted it. It rebooted but I don’t know how to reinstall it??
You rebooted it but did you factory reset it? or just reboot it?
here's where you can get the install manual.
