Trippy86
Dec 15, 2016Tutor
Netgear Nighthawk EX7000 connection issues
Hi ive had the EX7000 for about a month and have had a few issues with devices connection Firstly i have two nas drives connected directly to the EX7000, a WDmirror and a WDmycloud. If my la...
Trippy86
Dec 18, 2016Tutor
Can anyone help? i would love to get it solved asap
thanks so much
DarrenM
Dec 21, 2016Sr. NETGEAR Moderator
Hello trippy86
are you using the latest firmware on the ex7000?
DarrenM
- Trippy86Dec 22, 2016Tutor
hi yes its the latest
- Hardware Version: EX7000
- Firmware Version: V1.0.0.50_1.0.102
Connection to Existing Network (2.4GHz)- Signal Strength: 130 Mbps
- Name (SSID): VM******-2G
- Connection Status: Connected
Connection to Existing Network (5GHz)- Signal Strength: 450 Mbps
- Name (SSID): VM******-5G
Extender WiFi Status (2.4GHz)- Name (SSID): VM******-2G_2GEXT
- Region: Europe
- Channel: Auto (11)
- Wireless mode: Up to 600 Mbps
- Wireless AP: On
- Broadcast Name: On
- Wi-Fi Protected Setup: Configured
Extender WiFi Status (5GHz)- Name (SSID): VM******-5G_5GEXT
- Region: Europe
- Channel: 36 + 40 + 44(P) + 48
- Wireless mode: Up to 1300 Mbps
- Wireless AP: On
- Trippy86Dec 27, 2016Tutor
any other ideas?
