Ivawil
Aug 16, 2021Aspirant
Netgear Nighthawk wifi range extender no longer works with Comcast XB7 modem
I installed the newest XB7 modem from Xfinity and now my Nighthawk Wi-Fi range extender no longer works. I get the WPS connection working but the wireless connection drops after a minute or two. Help!...
Ivawil
Aug 17, 2021Aspirant
Thank you. However, I have tried using the smart setup installation assistant numerous times, but the assistant gets to the point where you have to select either of the newly set up Range Extender's 2G or 5G wifi connections on the device I am using to access the assitant (my iphone 11) and I can't select either one, because there is no signal to the extender.
At this point, when I do try to connect to either the 2G or 5G connections on the extender in my phone's settings, I get a message on my phone that it is:
Unable to join the network (extender 2G name)
If your netowrk security is managed by Wi-fi address (also known as "MAC Address"), you may need to turn off Private Wi-Fi Address or modify your network settings.
Additionally, when I get to one of the set up steps in the Nighthawk setup and the prompt comes up saying it is installing my settings, the circle whirls around and around and then suddenly, I get a prompt that safari can't reach the internet and I am kicked out of the assitant.
I did read not to name the 2G and 5G connections differently and am using the same name and password for each. As I said, it was working perfectly until I installed the updated firmwared and launced a new Xfinity XB7 modem. I have to think one of them is causing an issue.
Aug 17, 2021Guru - Experienced User
during the setup installation process,hardwire a pc/laptop into the extender for setup.
disable the wifi on the pc/laptop you use for setup so it doesn't default back to wifi.
After setup, the mywifiext . net might not work. If it doesn't, log into the xb7 and look at its attached devices (or equivelent) page for the ip address of the ex7000. You should be able to use that to access it
- IvawilAug 17, 2021AspirantThank you. So the laptop/pc needs to be within range of the modem, right? So the extender has access to or is in range of the modem. Also, I am not sure how to use the IP address to access the extender.
- plemansAug 17, 2021Guru - Experienced User
If you factory reset the extender and hardwire a pc/laptop into it, you should be able to use the mywifiext . net address.
Or you can try the default 192.168.1.250
Set it up in the same room as the router. Once its setup, then you move it
