MichaelAE
Jan 24, 2018Aspirant
Netgear Nighthawk X4 AC2200 Wi-Fi Extender Wall Plug Edition (EX7300-100AUS) keeps asking for passw
Hi, My ex7300 extender has started to cause a problem in the last 2 weeks. Every morning the extender asks for the wifi password but it does not recognise the password. It requires the extender to b...
- Feb 09, 2018
Hi MichaelAE,
Region only limits the number of channels available for that region, but changes in environment or devices might need modification in wireless channel. So any router which belongs to any region must give a choice to modify wireless channel. You need to change the wireless mode on your WPN802 to modify wireless channel.
DarrenM
Jan 30, 2018Sr. NETGEAR Moderator
Try to factory reset the extender by holding the reset button for 10 + seconds then set up the extender again like a new install. Also you may want to tell your devices to forget that network untill you have it setup again then connect those devices.
DarrenM
- MichaelAEJan 31, 2018Aspirant
Hi Darren,
I tried the solution below. However unfortunately this does not resolve the issue. Are you able to assist further.
Thanks,
Michael.
- jvasanth1984Jan 31, 2018Virtuoso
Hi MichaelAE,
Can you check and modify wireless channel on your router/gateway to see if you witness this issue? Are you coming across this issue after firmware upgrade?
- MichaelAEFeb 01, 2018Aspirant
Hi jvasanth1984,
Thank you for your reply. The wireless router I have is set to channel 6. However it does not allow the option to change it. The issue started occurring randomly. It had been working fine for months previously. Due to it not working, I then performed a firmware upgrade thinking that this would resolve the problem. I also performed a factory reset, however this did not resolve the issue either. Could the extender be faulty?
Michael.
