ajwary
May 12, 2016Aspirant
netgear nighthawk x4 EX7300,
After successful setup, I thought of changing location of the router and the extender , after rotating the location extender will not extend any thing all lights are green but no affect on devices ,...
- May 17, 2016
Hello ajwary
I fixed your registration date on your extender. But when doing the factory reset have you made sure to hold down the button for 10 seconds? Also you may want to try and connect the extender to the router using WPS.
DarrenM
ajwary
May 17, 2016Aspirant
Thank you for fixing the registration date
Problem has been solved. Device is working
Thanks
Thanks
