1WtRngoFan's avatar
1WtRngoFan
Netgear Nighthawk X6s and bridging
I am currently using a Netgear Nighthawk X6S for my in home routing solution for my current. im not very network savy but id like to utilize my same network/wifi in a shop that is about 100' away from my home without running a cable between the two. With things moving in the direction of smart devices I already have several needs for wifi in the shop given garage doors, door locks, lights, etc. Any help, input or opinion is appreciated. And thanks for your time.
1 Reply
  • plemans's avatar
    100ft is quite a ways with it being wireless as well as exterior walls tend to block wifi the best. Reason why is the insulation, the exterior covering material (cement board, metal siding, adobe, brick, etc all block wifi very well)
    What is the exterior of the home made from and what is the garage exterior made from?
    Its kind of key as you can sometimes get wifi to transmit that far but if the exterior is made from those materials it usually degrades the signal to much.
    Then you start looking at point to point systems to connect the two buildings. (like netgear's airbridge)
    Which can get expensive. Suddenly buring a wire and adding an access point or hardwiring in an extender becomes feasible.
