Stuartzm
Dec 25, 2018Aspirant
Netgear Powerline 1000 PL1000 - wifi access failing
Hi - My Netgear Powerline 1000 booster has worked fine I then got a new modem. Now I cannot get any devices (ipad &iphone) logged onto the signal despite that all the LED indicators are showing gree...
- Dec 30, 2018
Ok, i have got it running. I started from the beginning again, I replaced all cables, did factory reset on modem and netgear and got the ethernet cable to computer and netgear working, range extender is now also working. I don't really know what I did, but thanks Stephen B for your input.
Dec 27, 2018Guru - Experienced User
Stuartzm wrote:
Do I need to allow/authorise access (somehow) to the netgear expander to connect to my modem?
Normally not, since it is connecting over ethernet and not wifi. Though if your new modem is set up to use mac address filtering (blocking unknown devices from connecting), then you should probably try turning that off for now.
Stuartzm wrote:
Thanks for your suggestions. Yes I have 4 Lan ports and tried them all. Also lights on the modem port is lit when the cable is connected , but they do flicker. Same issue persists.
Just to be clear - the Link LED for the router LAN port that is connected to the PL1000 is lit?
Also, have you tried connecting a device to the PLW1000 (wifi module's) ethernet port, and see if that connects?
Stuartzm
Dec 27, 2018Aspirant
Hi StephenB
Yes, the LAN port is lit when cable plugged in. When I try to connect via ethernet port, both directly modem to my Mac and Mac to the PLW1000 plugged into the wall socket I get the following on both occassions
Status: connected
Ethernet has a self-assigned IP address and will not be able to connect to the Internet.
Configure IPv4: Using DHCP
IP Address 169.254.205.196
Subnet Mask: 255.255.0.0
Router:
DNS Server:
Search Domains:
Thanks
- StephenBDec 28, 2018Guru - Experienced User
Ok, that is a clue.
Can you open CMD on the PC, and then enter
ipconfig /renew
That might get you an IP address. If it doesn't, you could try assigning a static IP address to the PC.
Once you have a valid IP address for your network, try pinging the router.
It is of course possible that one of the modules has failed (still giving you an ethernet link, but not end-to-end connectivity).
- StuartzmDec 28, 2018Aspirant
StephenB wrote: "Can you open CMD on the PC, and then enter
ipconfig /renew"
I understand, (google search) that the "CMD" on a Mac is opened via "Terminal" that is in "Utilities in Applications" so i enetered ipconfig/renew and pushed enter and this came up.
Last login: Sat Dec 29 08:17:47 on ttys000
Stuarts-MacBook-Pro:~ stuartdunlop$ ipconfig/renew
-bash: ipconfig/renew: No such file or directory
I then closed it and this came up when i reopened it
Last login: Sat Dec 29 08:27:58 on ttys000
[Restored 29/12/2018, 8:30:09 AM]
Last login: Sat Dec 29 08:29:50 on ttys000
@StephenB wrote: That might get you an IP address. If it doesn't, you could try assigning a static IP address to the PC.
Sorry, I have no idea how to do that either, I am pretty much a novice when it comes to technical side of things on a computer. Also I have no idea how I would try "pinging the router" if and when I had a valid IP address.
Thanks
Sorry, forgot that you were using a Mac. I don't own one, but I believe the correct procedure for OS X is is to
- Click the Apple button and choose System Preferences.
- Click the Network icon in the Internet and Network section.
- Select your method of connecting to the internet (Ethernet or Wi-Fi.)
- Click Advanced.
- If you selected Ethernet, you should already be in the TCP/IP tab heading. If you aren’t, or if you selected Wi-Fi, click the TCP/IP tab heading.
- Click Renew DHCP Lease.
- Click OK to exit the Advanced window, and then exit System Preferences.
